For comfort cooling vapour absorbtion system can be used if you are getting some waste heat.
Lithium Bromide-Water system can be used upto a minium temperature of -5 deg C and Ammonia-water system can be used upto -30 deg C below this temperature heat ratio is very low and you need a very high temperature heat source.
KMPillai
