About X10CrMoVNb9-1 (EN 10222-2 )
Raaden
SE
Hi!
My question is short and simple: To what material group does X10CrMoVNb9-1 belong.
The material is not listed in either EN-1092-1, ISO-7005-1 or prEN-12516-1 so if someone has any bright ideas, I would apreciate the help
Pontus
looks like a high alloy stabilized grade of stainless steel.
Other than that I'm of no help.
Nick
I love materials science!
The standard EN 10222-2 is entitled Steel forgings for pressure purposes - Part 2: Ferritic and martensitic steels with specified elevated temperature properties. Grade X10CrMoVNb9-1 would be considered a high alloy steel, not a stainless steel, since the Cr content is only 8-9.5% The microstructure that develops upon normalizing is a mixture of ferrite and bainite. The tempering operation causes fine M23C6 precipitates to nucleate on prior Nb(C,N) particles.
Thanks, but but what I'm looking for is the actual group No. for the material.
For example:
P265GH belongs in group 3E0
13CrMo4-5 belongs in group 5E0
10CrMo9-10 belongs in group 6E0
So ewhere does X10 fit in?
Try prEN10028-2,Matl 1.4903; ID 3244 for plate Reg AD-W-1
1,4903; 0865 bar
Spec VdTuv 511/3
Also under CR ISO 15608: Material Gr 6.4 for forgings
EN 13445-2:2002 Issue 6
Also En10216-2
Sorry about the lack of uniformity as I am not that familiar with EN specs. This just a copying from tables with small print.
Hi Raaden,
The grade you mention is listed in the SEL 2000 and is WNR. 1.4903
Its also listed in the DIN EN 10302:2002:09 ann the DIN EN 10028-2:2003:09
Best Regards
Richard Buss
The material is same as A 182 F91.
To what group it belongs can not be answered because you do not specify the purpose or Code you refere to.
E.g. for welding qualification per EN 288-3 the group will be 6.
The material group I'm looking for is the "EN-version" of the material groups found in ASME B16.5 & ASME B16.34.
As I mentioned in my original post, X10 is not listed in either EN-1092-1 or prEN-12516-1 (which are the ASME counterparts)
