Dear all,
Here is a question(s) about the stability criterion in a dynamic explicit analysis.
In ABAQUS user's manual I red that the stability of an explicit procedure can be ensured if the time-increment is small enough. Then, as a limit criterion of stability, the given time-increment should be less than 2 / Omega. Omega is defined as the frequency of the entire system ... so my questions are :
1) I can't really see what Omega stands for ... does anyone see better than me about that said frequency ?
2) I also estimated the stable time-increment to be about 1,0E-07 s given my material's constants and given the smallest element size of my model (delta_t = L / c). Still, how can I ensure myself that the solution given by such a time-increment is sufficiently reliable indeed ?
Any response from you will be meaningfull I think
I realise a tensile simulation using a viscoelastic law.
Thank you in advace,
Mandriam
Mandriam
