ABAQUS WARNING
817mir
MY
Greetings.
Im modelling concrete beam by using parameter of Concrete Damage Plasticity. Can someone help me why i got the warning of
'ouput request damage t is not available for the material for element type c3d8r' ???
Which version of Abaqus do you use and which options did you specify for CDP material ? Are there any other material models used in this analysis ?
im using 6.14 version. im choose from other journal to specify the CDP material.
yes,include of beam, steel and stirrup. is it something wrong? can help me please im new learner
Most likely this warning message simply means that DAMAGET variable can’t be calculated for parts of your model meshed with C3D8R elements that have different material than concrete assigned to them (for example steel parts). If you open results and create contour plot of DAMAGET you should see that some elements are colored and some are left gray (no value). This is normal because DAMAGET variable is only used for CDP material model.
