I am thinking about modeling a wall system. The wall system will consist of a reinforced concrete column in between two masonry infill walls.
As shown here:
I wish to investigate the effect that the masonry infill walls have on the column due to the fact that the walls do not go up to the full height of the column (creating a captive column condition and causing an earlier failure of the column than what would be expected.)
My questions are:
1. As I have never used ABAQUS before, how difficult would it be to model this system. Mainly pertaining to the material properties of the column.
2. If I am mainly interested in the Z-direction behavior (I plan on applying a displacement at the top of the column in the Z-direction), what would be the best way to model this wall? (i.e. 3D or 2D analysis)
Thank you,
As shown here:
My questions are:
Thank you,
