first of all thanks again for your replies.
I'll show you what I am doing. Basically I am running some parametric studies of a simple buckling study of a beam. In order to run parametric studies, you have to add in the input file, which was generated from the Abaqus CAE, a parameter definition, (*PARAMETER/ dy1=-0..05), and in the parameter usage instead of the value, <dy1> must be written. In my case was the vertical displacement of one of the beam extremity is the parameter:
*PARAMETER
dy1=-0.05
** MATERIALS
*Material, name=Al
*Density
2.7e-09,
*Elastic
70000., 0.3
** BOUNDARY CONDITIONS
** Name: END1 Type: Displacement/Rotation
*Boundary
Set-9, 1, 1
Set-9, 2, 2
Set-9, 6, 6
** STEP: ENDs Rotation
*Step, name="ENDs Rotation", nlgeom=YES
*Static
0.1, 1., 1e-05, 1.
*Boundary
Set-9, 6, 6
** Name: END2 Type: Displacement/Rotation
*Boundary
Set-10, 1, 1
Set-10, 2, 2
Set-10, 6, 6
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT, frequency=10
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT, frequency=10
*End Step
** STEP: Vetical displacement
*Step, name="Vetical displacement", nlgeom=YES
*Static
1., 1., 1e-05, 1.
*Boundary
Set-10, 2, 2, <dy1>
** OUTPUT REQUESTS
*End Step
** STEP: Precompression
*Step, name=Precompression, nlgeom=YES
*Static
1e-15, 1., 1e-15, 1.
*Boundary
Set-10, 1, 1, -0.03
** OUTPUT REQUESTS
*End Step
** STEP: plot
*Step, name=plot, nlgeom=YES, inc=1000000000
*Static, riks
1e-06, 1., 1e-08, 0.005, , END2, 1, 1e-08
*Boundary
Set-10, 1, 1
** OUTPUT REQUESTS
*End Step
After that, to run parametric study a psf file in Python must be written:
dy = ParStudy(par='dy1', name='Istatedy')
dy.define(CONTINUOUS, par='dy1', domain=(-0.7, -1))
dy.sample(NUMBER, par='dy1', number=2)
dy.combine(MESH)
dy.generate(template='Istatedy')
dy.execute(ALL)
dy.output(file=ODB, instance='Part-1-1', request=FIELD, step=4, inc=1)
dy.gather(results='n257_u', variable='U', node=257)
dy.report(PRINT, par='dy1', results=('n257_u.2'))
It automatically generates different jobs which can me automatically submitted.
Now the problem I have, is that I want to create a file with all the displacement values of each increment of the step 4(plot). This should be done in this line: dy.output(file=ODB, instance='Part-1-1', request=FIELD, step=4, inc=1) but instead of inc=1, something that will give me all increments, I tried with inc=ALL and many others.
