swahlgren
- Jul 1, 2015
- 14
Hi guys,
I am running a parametric study with Abaqus and it runs just fine but I am having trouble extracting the results I am looking for:
[ul]
[li]The x-coordinate of a node that is defined by a nodeset with a single node. The node number for the nodeset is a parameter in the study so it changes with each run.[/li]
[li]The J-integral of a contour around a crack tip. The crack tip etc. have been defined so the J-integral is calculated - I just need a way to retrieve it as a result of each run.
[/li]
[/ul]
Hope you can help!
[ul]
[/li]
[/ul]
Hope you can help!
