Abhishek Paul
Hello all,
I have faced a runtime error with Abaqus/Explicit of the form "terminate called after throwing an instance of 'nex_PrimException<atr_String, 1>". The job is being run in parallel MPI on 128 processers. I cannot find the source of this error, there are no distorted elements in the .odb file. Is there any online resource (apart from Abaqus documentation) that enlists the different possible abaqus runtime errors. If not, do you guys know of other forums that can help with this issue?
Thank you for your help. I have attached an image of the last few lines in the .sta file
-Abhishek
-Abhishek
