Abaqus Cortical Bone Model
MyersUSA
Bioengineer
I have an Abaqus file of a cortical bone model that was created using an older version of Abaqus.
Does anyone have the ability to open this file and possibly post the output file?
Thanks!
You can open it up with the latest version and it will be updated. Warning Abaqus does not have backwards compatibility. I hope this helps.
Rob Stupplebeen
Thanks for the post. I actually tried that, but I kept getting a error saying that it could not update the file and that I had to go into the abaqus environment file and turn something OFF. I'm not a software guy, so I could not figure out how to do it.
If you have the latest version of Abaqus and you can open my attached file, I would GREATLY appreciate just posting the resulting output file.
Thanks again.
Attached are the desired files. If you browse to C:\SIMULIA\6.10-1\site and open abaqus_v6.env and add the following lines to the file you could get it to work. I would suggest removing them when complete.
import os
os.environ["ABQ_STREAM_VALIDATION"]="OFF"
Rob Stupplebeen
 http://files.engineering.com/getfile.aspx?folder=7275bf44-d1e3-4110-8a33-5b4032c1995e&file=Job-3.zip
Thanks!!!!! That worked great!!! You are awesome. I really appreciate your help!
