ABAQUS Contact Element Problem
PJtree23
Bioengineer
Jun 11, 2008
14
I just started ABAQUS last week so bear with.
Im trying to get two (2D) beams to come into contact and continuously deform together under a distributed load.
I can not get the beams to stop going through each other. When I define a master/slave surface along with ridged constraints the code never complies and I get swapped with errors.
Does anyone have a link or a file of a tutorial for setting up a basic case of two beams colliding?
Thanks,
PJ
Even though the problem isn't really anything like what you described you might want to look at "1.1.4 Indentation of an elastomeric foam specimen with a hemispherical punch" in the example problems? When I was having a similar issue (not too long ago) this helped me out a lot.
Also, the verification manual has a whole section on contact problems.
Hope this helps.
Dan
