It seems like I am having issues with what I consider are basic operating features of any FEA package.
To start with, I am not able to delete quad elements from a mesh. I created a shell (plate) with 0.1" thk and assigned it a simple 4-node shell quad element. I have defined the Assembly Instance as Defined. When I try to delete an element from Mesh->Edit->Element->Delete, I get the following error.
The manual says that I am supposed to get a Mesh Edit menu with more options. Somehow Abaqus is not presenting me with such an expanded menu.
Secondly, If I want to apply a Concentrated Point Force on a node via GUI i.e. Abaqus CAE, how do I achieve it? All I get is an option to chose points. Again I read in another thread that I am supposed to get an icon where I can select to apply it on nodes.
Lastly, I had asked this question in a different thread. Asking it again here. I have applied a shell edge load of 40 lbs/in. This model is simple and thus I can calc the total load & moment. Is there an utility to check value of total external loads in Abaqus before submitting it for analysis?
Thanks in advance...
