A325X Bolt length calculation
MadhuBR
Is there any formula for A325X bolt length calculation or its same as usual bolt length calculation
Bolt length -- as in which length bolt to order?
Same as any other structural bolt, with the added step of making sure the shank length is adequate to achieve an X condition (depending on number and thickness of plies, etc.).
just call me Lo.
And depending on your relative ply thicknesses, the bolt may only be 'X' if installed in one particular direction.
I avoid specifying X bolts (threads excluded from the shear plane) due to the real possibility of a bolt mix-up on site.
