ginsoakedboy
Say, we have modeled a transient heat transfer problem (cooldown of fluid within an insulated pipe) using 2 different numerical techniques; FEA and CFD.
Next, we conduct an experiment to obtain some data for benchmarking.
Now, when we compare the temperature results from numerical techniques against the experimental data; is it justified to use a percentage basis for evaluating accuracy of the simulations? Note that percentage change in temperature is inherently meaningless because of arbitrary nature of the temperature units.
Is there a construct that will allow a relative measure for accuracy of 2 different techniques? Thank you in advance.
