Hi all,
I have worked with explosion loads and the design for that purpose on and off for several years. But last week a got a odd problem.
A client has a building and the process inside can explode if things go bad. The current solution is venting areas, hatches in the wall that will open for a certain pressure, releasing the explosion. It is a standard approach so nothing strange so far.
But now they need to install a chicken wire fence in front of that wall, due to other reasons.
Question 1: Can the chicken wire fence reduce the pressure on the venting areas so that the hatches in the venting areas don't function as intended?
Question 2: Will the chicken wire fence be damaged by the explosion?
Does anybody have any ideas or experience regarding this? Any reference would be appreciated.
Thomas
Thomas
