In discussion with others a question was raised.
On a calm day there are two identical trucks pulling identical trailers at a very high rate of speed. They are on the same road and the distance between the two is far enough to not affect each other. If one truck has a far greater mass than the other, is the air turbulence different from one to the other?
Also, if equal acceleration was experienced would the answer be the same?
