Overunity_1
Forgive my ignorance here as I am an Electrical Engineer, but I have a question regarding using A-Frame bus between rigid bus pipes in a substation. Are these A-Frames considered structural, the same as an insulator? If so how are you calculating the force on the lower bus? Is there anyway to do this without FEA? I've gone through IEEE605-2008 and its my understanding that this standard doesn't apply to A-frame connections as you need to implement FEA to model the flow of short circuit current through the A-frame itself.
I can't seem to find any advantage over using an A-frame bus pipe setup over just dropping a strain bus tap down, unless these can be utilized as a structural support, relying on the insulator strength from the lower bus insulators.
