A cantilever beam subjected to the uniform pressure load
Yuchi Kang
New member
SE
Hello everyone,
I am trying to calculate the max deflection u2 of a cantilever beam. The cross-section is circle whose radius (r) is 0.01m and length (l)is 1m.One end is fixed and one end is free. This beam is subjected to a pressure on its upper circumferential surface with 10000Pa. In order to verify this model, I calculate the deformation in this way:
p*2r*(l^4)/8/E/I
E is 210*10^9Pa, I=pi*(2r)^4/64
The hand calculation of deformation at the free end is 1.516mm. However, the numerical result is 1.627(for C3D8I) and 1.704 (for C3D8R).
What's the reason for this discrepancy?
Yuchi
Hi, IceBreakerSours.
Total element is 5200. The globe size is set as 0.005.
Correct me if I am wrong: Are you saying you have 20 elements through thickness? If yes, then (keeping your question aside) that seems overly excessive.
More importantly, on the analytical side, you have a long and thin beam under stress. I have not done any hand calculations but I wonder if the theoretical assumptions are even valid.
Are you new to this forum? If so, please read these FAQs:
Hi. Sorry for reply late. I think it's correct about the analytical side although Large deformation is considered. I think the main reason maybe associated with the element type(C3D8I). I will continue to work on this then post my new findings.
