80 years of glued laminated timber 2
ThePioneer
19
The structural glued laminated timber industry in North America is now 80 years old. The very first glued laminated timbers made in North America were in 1934 at Peshtigo, Wisconsin. Those arches are still standing and supporting the roof of the school library in Peshtigo.
For those who may not be familiar with Peshtigo, it's in Northern Wisconsin, not far from the border with Michigan's Upper Peninsula.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Yes, didn't Peshtigo burn down on the same day as the great Chicago fire?
In reality, on the same day as the 'Great Chicago Fire', four other cities in Michigan and Wisconsin were also destroyed, or nearly so, by fire, but the Peshtigo fire was the deadliest as it destroyed the entire city as well as several smaller nearby towns as a forest fire swept in from the West and burned everything in it's path, right down to the shoreline of Lake Michigan. There never was an accurate count of the dead but some estimates placed it as high as 2,500, making it the deadliest fire in the history of the country.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The Peshtigo Fire was on 08 October 1871 the same night as the Chicago Fire. The Peshtigo Fire destroyed 1.2 million acres and killed between 800 and 2,000 people. It destroyed much more than just the village of Peshtigo and adjacent areas.
At that time Peshtigo was home to the world's largest woodenware factory, making all sorts of wooden products for everyday use: shingles, pails and all sorts of buckets, much more and of course, lumber.
It is fitting that the town that arose from the ashes of the 1871 fire was ultimately become the birthplace of the structural glued laminated timber industry in North America in 1934. The laminating plant in Peshtigo is still in operation.
So what was the glue in the original beams? was it hide glue , Casein , or did they have access to the phenolic resin glues by then?
B.E.
Casein adhesive was utilized in the glued laminated timber industry by and large until the 1960s. It is a good adhesive, not waterproof of course, so can only be used for interior applications. Waterproof resorcinol and phenol resorcinol adhesives were used during World War II for marine applications. They were not universally adopted by the structural laminating industry until the 1960s.
The Peshtigo and Chicago fires deforested much of Wisconsin. First by fire, then by the enormous demand for timber that followed immediately after.
These events, as well as the other fires mentioned earlier, did a number on the standing timber in Michigan as well. The town I grew up in Northern Michigan was one of those that started out as a lumber camp which then grew to a substantial lumbering and saw-milling operation, but which died out after the turn of the century (1900) as the forests were cut-over and the big lumber operations started to move further west where there were still stands of virgin timber.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
So, with this date of construction establishing the glued laminated beam use, when was "plywood" first used?
And, over time, how long will the tens of millions of plywood house widely built after the war begin loosing roofs and walls as the plywood delaminates from itself?
Ra cook pe,
I cannot answer the first part of the question, however I did get a practical answer to the second part of the question.
2 years ago I re- roofed my house which was built in 1962, over 85% of the plywood had to be replaced because it was de-laminating. It appeared to be a urea formaldehyde type glue ( clear) which was not holding up, other sheets that had resorcinol type glue appeared to be fine.
B.E.
Glued veneer plys were found in tombs of the Eqyptian mummies.
ThePioneer,
Glued veneer plys should work well in mummy tombs. It is moisture that attacks mummies and plywood adhesives, right?
JHG
The Mosquito wasn't the only WW II aircraft to use glued wood structures, but it's a great example.
The F4U Corsair had plywood elevators.
old field guy
Yeah, but the Mosquito used it for primary structure and was very high performing.
Many aircraft of that era used wood of one kind or another in some more or less significant way but Mosquito stands out in terms of amount used and relative performance.
My grandfather owned a plywood factory in Luebeck, Germany. That kept him from getting drafted in WW2. Then he ran afoul of the SS and hid from them by enlisting in the army.
