I have a project where I have approved mix designs for all of my cast-in-place concrete. Each design has properly graded aggregate.
Now, the GC has asked if he can use a different mix on the elevator pit walls. He tells me that he's poured his footings, doesnt want to take the concrete truck over the footings, doesn't want to bring out a concrete pump to get the properly graded concrete to the pit walls, but, can have his mason use his grout pump to pump concrete with #78 stone (pea gravel), that is normally used to grout CMU voids in reinforced masonry, to the elevator pit, in order to pour the walls.
I am apprehensive about using this #78 mix, as it is not as well graded. I do use this mix in reinforced CMU due to the limited space available for rebar and concrete, but, I have never used it as the concrete for a formed wall. I have been submitted a concrete mix design, and the compressive strengths are fine.....but for some reason, in my mind, this does not seem like a good idea.
Any suggestions or comments?
