mzaitz
- Sep 15, 2005
- 30
All
Working on a 4 story moment framed building and having issues with drift for wind. Building is 61'-4" tall (15'-4" floor to floor) not counting the mansard roof. I have worked on taller buildings but they ended up with braced frames or concrete shear walls. Building is L shaped with dimensions approximately 270 ft x 230 ft for the outside bend. The long side on the outside of the corner has a 5 degree slope in plan so all of my moment frames on the outside of the building are 5 degrees from orthogonal. After lots of reading, I decided to use H/400 for the building. Building is located in a 120 mph wind speed and SDC B. Using a 25 year return for the wind (factor of 0.49 for checking drift), I cannot seem to get the drift at the second floor to meet H/400 or even H/300. I am limited to W14 columns and they are getting large (W14x132 and larger) and increasing the weight has a small affect on the drift.
Having not done moment frames this tall I am working to eliminate the doubler plates (web panel reinf). Also, looking at using bolted flange plates instead of direct welding beam flanges to column. Anything else that is a major concern cost or design wise?
Thoughts for stiffening the building:
Use W18's for the columns. This will be a hard sell to the architect.
Fix the bottom of the columns to the footings. Not something I normally like to do.
Are there any other insightful ways to stiffen the building that I am missing?
