4-20ma wireless system
kiwisoundguy
GB
Hi There,
I am looking for a small DC (1.5-12v)powered 4-20ma wireless system. I need to transmit the current signal from about 30m away from my DC powered display. It only needs to be a one way transmit. There is no computer involved in any way. It is a simple loop circuit that I would like to have the cables removed.
Any ideas chaps? I noticed another topic that mention soemthing aout the Phoenix wireless stuff, but it looks quite big and the ability to supply that power / current is a worry.
Thanks in advance.
Ben
Do you have line-of-sight? An IR system might be easier and cheaper.
Benta.
Hi, LOS is possible but not always possible. What would you suggest in the infra red range? Would you also have some RF solutions?
Cheers, ben
Thanks for that. I have seen the Phoenix before, but it is too large and the power demands are too high. I loke the look of the Banner stuff, but I fear it may be the same.
Do you think I could converter 4-20ma to 0-1v or 0-5v and use a simple AM/FM TX/RX?
I suppose you can breadboard anything.
Banner's stuff runs on 10-30V dc, so 12Vdc is doable. They've also got battery packs that will run the transmit side. The receiver/gateway side should be line powered through a power supply.
Link to 10-30Vdc stuff:
