Feb 26, 2006 Thread starter #2 D DORA1 Guest Hello It couldn't be problem when you posses version 5 release 15 and minimum sp2 or maybe 3 then you can create it from Tools->Utility, so I heard about it that this should be working, good luck for trying. )
Nov 28, 2007 Thread starter #4 R ratnesh.patil Guest Hei, If you want to make .3DXML file, you just save your assemblyin .3dxml format. You can do this only in Assembly module. Edited by: ratnesh.patil
