3d xml
  • Thread starter Thread starter anjonebra
  • Start date Start date
A
anjonebra
Guest
where can i do files 3d xml or what do i need
Hello
It couldn't be problem when you posses version 5 release 15 and minimum sp2 or maybe 3 then you can create it from Tools->Utility, so I heard about it that this should be working, good luck for trying. :o)
hello again,
I can
Hei,
If you want to make .3DXML file, you just save your assemblyin .3dxml format.
You can do this only in Assembly module.
Edited by: ratnesh.patil
