3D piping drawing command
chicopee
I seem to remember an easy way of laying out piping in 3D however I forgot the command. The procedure was to draw the center line and then draw a circle on one end of the center line and invoke this "forgotten" command to have the circle extrude itself to follow the centerline.
Carl B- it is not extrude. This "forgotten" command will follow a path such as a center line that may have bends. The Extrude command will not bend.
Sure it will. Extrude [pick circle] Path [pick path]
Thanks You responders- somehow I forgot about the PATH option
