KevinNZ
- Jun 12, 2003
- 867
Can someone please recommend a reference for 316L corrosion resistance at elevated temperature.
We have a system with 316L water pumps operating at 110C and would like pump same fluid at 207C @18bar. What is the change in SCC resistance over this temperature range? Water cl- ~ 2140 mg/l.
Note the water is oxygen free and all the piping and valves are carbon steel.
I have done research and found
"temperature should be seen as a key indicator for susceptibility to
CLSCC"
"If free from oxygen, solutions will not cause CLSCC"
"The 316L stainless steel did not exhibit any evidence of IGSCC in 500°C deaerated supercritical water"
CLSCC"
