I'm posting a duplicate query here as well just in case you guys don't visit the "piping and fluid mechanics engineering" forum. Someone there suggested a welding forum, but I don't think there is one of those. Anyway...
Is it OK/common practice to weld 316L SS pipe to standard sch 40 carbon steel pipe or A36 steel plate? Are there any type of special welding materials/electrodes or special prep procedures that I should call out on the drawings/in specs?
Also, is there a dielectric issue with these dissimilar metals? I don't have water in the system. The application is more of a stack instrument test port nozzle.
And finally, if flanging/gasketing is employed, doesn't the gasket serve to dielectrically separate the two materials or do I need something else since the bolting bridges the materials?
Thanks in advance.
Thanks in advance.
