I'll have to give "mcguire" half credit.
Both alloys are produced in all forms though wire being the
biggest use.
314 S/S is widely used in used the fabrication of mesh belts for ovens of all kinds. Due to its' composition it has the highest heat resisting properties of the straight Cr-Ni grades. I don't have the data and the link is dead, but as I remember it, the continuous use temperature was around 1050°C.
308 S/S is also used in mesh belts but is primarily used as welding wire for 304 S/S. The continuous use temperature is 980°C
