3-way Valve in AutoPIPE 2
curtis2004
301
Hi Everyone,
I need your help in modeling of 3-way valve in AutoPIPE. I found out that it should be modeled as rigid element, which include 3 different valves with dummy legs converted into rigid tee. To be honest with you I have done this about seven years ago, but now I forgot. :)
I appreciate if somebody remembers and give me step by step instruction to follow.
Thank you all,
Curtis
Sorry, cannot help with the modelling part, and my comment might be far away from your case here.
The question for three-way valves at construction /planning stage is always if the solution in any way can be avoided and replaced with a combination of standard valves.
Note: it is OK to use this solution if there exist commercial available valves that suits the application.
There should be some direction in the help file but here's what I recall from previous instants how I've done it;
- either model a tee (with flanges at all three ends) and with dimensions equal to the valve, and make the tee rigid. Add a weight to compensate for the valves weight. This will simulate the same thing as the second option below.
- make a tee with dimensions of (say) 0.5 mm. in all three directions. Make the tee rigid. At both run ends and the branch, insert a valve (now with a flange at only one end). Dimensions of course should equal the valves overall dimensions.
I believe the only difference between both options is that when modelling it as a 'true valve' (second option), autopipe gives the user more options to add certain features, like valve weight, actuator weight and length, buoyancy options, auto-insert of flanges at the end (and perhaps a SIF but I'm not sure about that). In autopipe a valve is just a rigid piece of pipe.
Hope this helps.
Hi
I just got it:
1. Build 3 valves with 3 runs (dummy legs) connected into one point (like a Tee, but without Tee). Total dimension of each valve and corresponding run shall be equal to 3-way valve dimension. You can split overall weight of 3-way valve between 3 separate valves.
2. Convert each run using Modify/Rigid Options Over the range into rigid body.
3. Convert connecting node of all runs into Tee using Modify/Convert Point to Tee.
That's it!
Curtis
