3 Things that are never discussed in texts, forums or expert web sites:
1. depth of weld penetration into the base material, (depth of fusion is the correct term). It is well published that amp settings, type of process, type of shielding gas will all vary depth of fusion into the base metal, but I cannot find data on what those depths might be! And how much is sufficient to develop the intended weld strength?
2. bevel angles on V-grooves – is a CJP groove weld with a 45 degree included angle (subjected to tension only) equally as strong as a CJP with a 60 degree bevel? Stress equations NEVER account for this angle or any weld proportion execpt height and length.
3. size of root opening – considering the same CJP V-groove weld, the pre-qualified weld joints of D1.1, or AISC and even Mil-Std-22 are very specific about the minimum size of the root opening. Why is this? I used to think root opening had more to do with access and electrode size only, but why is the “minimum” opening size so restrictive and requiring requalification if varied?
Any thoughts/advice is welcome as these three issues (particulary the fusion depth) have bothered me for a long time. The literature does not address them very well.
Please and thankyou.
