For my application I am performing a study specifically on a motor drive and am in the process of developing the test setup. Right now, the drive is powering a 3-phase, 3HP, 460V induction motor (referred to as the first motor) who's shaft is mechanically coupled to an identical motor (referred to as the second motor). I am powering the motor drive with a 3-Phase, 15kW, 208-480VAC transformer.
My goal is to watch the thermal response of the motor drive's circuitry as the amount of current being delivered to the motor is increased. In order to increase the amount of current being delivered by the drive (maintaining a constant RPM), I would need to increase the amount of torque experienced by the motor. This is where the second motor comes in handy. I am wondering if there is a way to control the second motor in order to vary the amount of torque experienced by the first motor. One colleague suggested a bidirectional motor drive - which I know nothing about and haven't been able to find much information on it.
From what I understand, in order to generate power from the second motor in this setup, the second motor would need to be rotating faster than its synchronous speed (which I believe to be 3450 RPM - the motor's nameplate speed). Therefore I do not believe it would be possible to attach capacitors to the leads and attach a load this way due to the fact that the first motor will not run faster than 3450 RPM. Am I mistaken?
I hope this was clear and I appreciate any and all feedback.
Best,
David
Best,
David
