abc_poster
- Aug 22, 2020
- 2
Hi guys,
I've got a question regarding 3 phase grid-tied solar inverters without a neutral (3-wire type). How does a 3 phase inverter without a neutral supply power to single-phase loads? Since it doesn't have a return neutral to the inverter how does the circuit complete it's loop? I've got advice that it can't, which I don't quite understand. The reason being, if say L1 from the inverter is exporting power to the grid and L1 has a single-phase load on it, it would mean current would need to move from the grid to the load on L1 while L1 is also exporting. As the current can only move in 1 direction this naturally can't occur.
This makes me think that the inverter supplies power to the single-phase load and the excess gets exported out to the grid but how does the return path occur?
Hope this makes sense! Thanks in advance folks!
