In addition to Gunnar's post, (I like to resolve the loads to single phase also, when possible)
There is the added factor of power factor. Both displacement power factor and distortion power factor.
With AC you can not work with Volts and Amps alone. Even when the power factor is unity, calculations which do not show that unity power factor is considered may be suspect.
Bill
"Why not the best?"
Jimmy Carter
