kingtutley
Ok, here is another newbie question.
I understand the physics behind the induction motor and the electromechanics, but what I don't get is the slip.
I know the math behind it, but I don't understand how it the rotor can be running slower than the rotating field.
Here's what I mean: I have a motor starting under no-load condition. The 3-phase rotating field induces the voltage on the rotor and the rotor begins to turn from bring push/pulled, right? Ok. Now when the rotor reaches full speed, it is said to be running slower than the stator field rotation. How is this possible? If the rotor is running slower than the field it would eventually stall wouldn't it -- like a synchronous motor being dragged beyond the torque limit? I understand that there should be a phase angle difference, but it seems to me that it has to be running at the same speed as the field in order to keep running.
So, what am I missing?
