WWTEng
- Nov 2, 2011
- 391
From what I understand, 2x6 T&G can’t be used as a means for diaphragm load transfer, so there has to be a layer of plywood or OSB over T&G to act as a diaphragm. The architect in his section is showing 2x6 topped with 3 layers of rigid insulation (3” thick) and on top of that he is showing plywood. Could I use this plywood as the diaphragm with insulation sandwiched in between?
