indkitty,
Slot size cannot be exactly 45 and 65. Do you want to have 45 minimum and 65 minimum? If yes, what would be allowed maximum on those? Or do you want to have 45 maximum and 65 maximum? If yes, what would be allowed minimum on those? Only knowing this we can help you.
The approach you have taken with profile plus position tolerance on the slot is quite a good choice. I would just place all around symbol (circle) at the junction of leader line from the feature control frame and add 2X basic R dimension to one of the radii of the slot.
Like I said, give us the minimum and maximum allowable values of slot's width and height, and then it will be most likely possible to play with profile and position tolerance values to meet your requirements.
