2deditor compatibility with a 64 bit machine
lonsgsp
37
It appears as though the 2d editor program is only for a 32 bit machine. I was recently upgraded to a 64 bit machine and need the ability to edit and at times, create, dwg files.
Does solidworks have a program similar to the 2d editor that is compatible with a 64 bit machine?
I haven't had any problems with the 2D editor running on my 64 bit machine in the past, however I haven't used it since upgrading to 2010. What sort of problems are you having?
