I have been running into a few problems using sketch picture. I have been asked to vectorize some old hand sketched drawings (later these will be converted to 3D parts). The drawings are full scale and have NO dimensions. Again, no dimensions but there are some notations that allow me to roughly verify the scale, and many parts with complex curves (aircraft airfoil) so simply creating a model from scratch is not an option. I was given full scale tif scans of the full scale drawings.
When I open the tif drawings up in paint shop pro and turn on the ruler I can verify that the image is pretty close to one to one. (There is a notation for an 1/4" ID tube and its pretty close to that via the ruler.) When I use the image as a background for "sketch picture" and I measure that feature it is roughly 2" dia rather than the actual size of 1/4". So why is solidworks scaling my picture? I can move/rotate the image but I haven't yet found a way to turn this scaling feature off.
Another question that is not related: Is there any way you can scale an entire assembly? Suppose I made an assembly model with 100s of parts and each part with a drawing, can I scale it up or down (maybe as a configuration) and it update all the parts and corresponding drawings?
