240V VFD substitute? 3
TurbineGen
489
I'm having a problem with a control system which requires speed control of 2 fans for coolers on a 25 MVA transformer. The fans are 5 hp and will be run at two frequencies: 45 hz and 60 HZ. The manufacturer has suggested using a VFD to achieve this. However, I really don't have the room in my control box. I'm already trying to fit 10 gallons into a 5 gallon bucket. Unfortunately I am unable to install and additional or larger control cabinet due to space constraints.
I was thinking of an saturable core reactor control or something to that effect. Does anyone forsee any problems with that? Are there any other possibilities?
I know it's seems ridiculous to run a cooler fan at reduced speed, but the reason for the dual speed is for noise limitations.
Any help or advice would be greatly appreciated.
If it is broken, fix it. If it isn't broken, I'll soon fix that.
Ozmosis, I'll definitely consider that.
Thank you all. You've been an incredible help.
Good call, Ozmosis, I was not aware of the J1000.
TurbineGen, note that I chose a 10 HP model assuming you can drive the two motor/fans in parallel. Also I believe that the J1000 VFD does not require any air space on the sides of the VFD which also makes them more space efficient.
