20g in XYZ 1
Heraklion
New member
DE
Hi friends,
I have a problem with Definition of forces in FEM. I have a box and this box fixed in cabin of airplane and should stay undamaged in 20g in x-y-z by Crash.
The under contours (only left and right) are defined as constrains!
The box contains another box as mass for 2.5 kg!
And now my problem:
- Is that a crash(impact)simulation or I can define the forces in linear static!
The FEM Software is Fusion360 from Autodesk®
thanks a lot for your helps :)
 https://files.engineering.com/getfile.aspx?folder=a3c6bae9-3779-4e65-a23a-fb659203bbac&file=Bildschirmfoto_2019-03-20_um_20.58.19.png
you're being told specific requirement (20g) not a general requirement (survive a crash at 20 mph) ... so apply your inertial load.
I would not suggest fixing the edge constraint ... pinned if you have to. I am not a fan of FEA bundled into CAD as it tends to be too "simple"
Never used it. Many tutorials out there. One can apply in a linear static syudy a linear global load which can be a global acceleration.
See here
Link
Link
