haynewp
- Dec 13, 2000
- 2,328
Is there an ACI Code provision that states you have to treat a slab as 2 way if it meets the 2 way dimension criteria? For instance if you have a slab that is supported on beams all around and it is a square in plan. Why not just design it as a 1 way slab?
What problems could this bring about by doing this? Excess cracking under service loads in the weak direction? etc...
