WWT...agree. Minimal steel. Keep in mind that a topping slab usually has a higher slump than you've specified. If you have a 0.40 w/c, you will not get a 4" slump without some plasticizer. Also, a 2-inch topping will require smaller coarse aggregate, thus increasing the cement content. That will run the strength up likely above 3ksi. Your topping slab should also be more compatible in strength with your pre-cast, which is likely 4 or 5 ksi.
