We are building four 18" ID x 22" OD cylinders that require 5:1 safety factor at 2500 psi. The material sourced is a 4140 annealed tube with a mill cert yield strength of 62ksi. We have excess material on the ID to bore and hone the cylinder straight, but on the OD the mill specs say it could be 0.285" out of straight on our 12' length. Therefore, the wall thickness could be down to 1-3/4" on the tube in some locations. This would give me a 4.8:1 safety factor.
Can this material be heat treated prior to machining without distorting it too much? Is an 80 ksi yield strength obtainable with heat treating? The minimum yield I would like to see is 70ksi. Any ideas will be appreciated.
