17-4 PH Y/T ratio <0.7, low Yield for H1150
Diegol
Materials
MX
Hello
I have a 17-4 PH forging which was heat treated to:
Solution 1900°F for 4 hours
1st Precipitation hardening 1150°F for 4 hours
2nd Precipitation hardening 1150°F for 4 hours
Sometimes the Y/T ratio is ok 0.85-0.9, but sometimes it is 0.6-0.7 which means that the Yield is very low for a certain hardness.
does anyone might have a clue why this happens even in the same heat? And how can I increase the Y/T ratio?.
one chemical composition is :
C 0.026
Si 0.36
Mn 0.92
P 0.019
S <0.001
Cr 15.78
Mo 0.12
Ni 4.54
Cu 3.2
V 0.02
W 0.02
Co 0.03
Nb 0.24
Do you have microstructure comparisons? Are there any grain size differences?
What do you expect? I think you double aging hardening was to increase bit of ductility for a sour environment to decrease hydrogen brittlement, is this for a oil gas application?
Double long time aging can give you some reverse austenite, leading to lower yield. if you need higher yield, and higher Y/T, just aging once, or decease aging temperature.
Even small changes in aging temp will impact strength.
Your second age should be 10F below the first, and neither should ever go above 1150F.
One note of caution, there is nothing wrong with a 1150 double aging treatment for this material. It is stated as such in the literature. However, if you are using a double aging treatment cycle, you must cool the material to below 100 deg F between aging cycles.
