12MHz Sine to Square IC?
jamesnguyen
49
Hi everyone,
I have a 12MHz, 0.8Vpp clip sine wave coming from a VCO and I need to square up this signal to TTL-compatible logic. The TI's CDC3RL02 can do the conversion, but its output is only 1.8V. I will need another level converter to convert it to 3.3V.
Is there any IC out there that can convert 0.8V clip sine wave to 3.3V square wave?
James
What about an comparator with an open-collector output? The frequency isn't all that high, so there should be a few choices available.
image.php
Thank you for your advice.
How is the output jitter with a comparator? What's the advantage of an open collector output?
James
How about a 'zero crossing detector' IC? The function you describe is pretty much exactly what they're made for.
Output jitter should be ok if you keep the pull-up fairly low in value. The open collector would get around your interfacing problem to the 3.3V system if you can't find a comparator to work from a 3.3V rail.
Nice idea VE1BLL.
image.php
I agree with Scotty. The comparator would be the easiest. The open collector allows you to run any voltage output, within reason.
Other possibilities:
An alternative would be an op-amp to increase the voltage followed by a Schmidt trigger.
Use a dual op-amp and use the first one as an amp and the second one as a comparator.
Keith Cress
kcress -
