1
- #1
Help ... I'm unable to resolve this issue: When replacing 2-prong outlets with 3-prong, the consensus is that you have to run a seperate gnd conductor or install gfci ... The main panel has a neutral bus that is shorted to the ground bus (pretty standard). Since the neutral is "electrically" the same point as the ground, why can't a jumper be installed at the outlet from neutral to the ground post?? This is a 2-wire household with a ground bus in the panel!! Installing this jumper would be putting neutral and ground at the same potential at the outlet just as it is in the panel. CAN SOMEONE HELP, PLEASE?? What is the N.E.C reference?
