Hello, I need to change somme sett
Yassine Allouche
DZ
I need to change somme setting in rec*316 ABB i Can Do that on line with system running means substation in opération.
Your comment pls,
A REL-316? Is it redundant? If it is redundant, I would just cut it out prior to making your changes.
What relaying function is it performing?
Is it redundant?
I don't recall any inadvertent operations due to a settings change on a relay.
I still prefer to have them isolated or out of service for settings changes though.
That way you can test the changes, and make sure you got everything correct before you put it back in service.
