try to apply several stages of quenching upon austenizing, perhaps around 1000 degC. To obtain high hardness, you'll need larger austenite grain, such that nucleation could be minimized. Perhaps with a dual-phase or even a three-phase structure upon such stages of quench would increase the impact strength. You might want to use water quench as the last quenching medium.
You can have a start off with oil-air-brine solution/water...However, do keep in mind that you will need to keep in mind that time taken for each quench varies, and to find the perfect time, is through trial and error.
Good luck.
