Way back, when I designed this input, I put in a standard transistor stage in order to boost the input 10MHz sine wave to something a 74HC14 could handle.
As it much later turned out, the input level was about 1.5Vpp, so I have had quite some difficulties in reducing the gain in the stage. The transistor output is DC coupled to the HC14, which might not have been the best of my ideas at the time
However, I have x-tra 74HC04 inverters available nearby. But how fast can one of theese digital CMOS implemmented linear amplifiers run?
All I need seems to be a gain around 2, giving me 3Vpp for the schmit-trigger.
10 MHz in ---- Cap --- Res ------ HC04 inv ----------- Boost out
------- Res --------
