T-Bracket Beam Analysis 1
E-N-E ENG
What's the pull force on the top bolt in terms of the point load, F?
Need to determine the pull force on the top bolt to find the pre-load (T = k x F x d --> F = T / (k x d)) to ensure no separation.
You may look to AISC Design Guide 1 Base Plate and Anchor Rod Design.
Assuming the base plate is rectangular or square , pull force P would be approximately P=8F/6= 1.33F.
Don't pull too much the concrete may break out. ( check probable failure modes).
My guess is there is no concrete involved here.
[Moment load F x 8] / [distance from top bolt to bottom bolt 6] = 8F/6 = 4F/3
Correct explanation?
Thank you
Folks... trying to analyze this further:
At interface 1 - plate to SEPARATE (BOLT 1 IN TENSIONS)
At interface 2 - plate to COMPRESS (BOLT 2 IN MOMENT ??)
Is the BOLT 2 under MOMENT load (top half in tensions and bottom half in compression)?
Thank you
8 x F = (1x edge + 2 + 4) x T1 + (1x edge) x T2
T1 / T2 = (4 + 2 + edge) / edge (ratio of distances from free edge contact point)
T1 = tension load at bolt 1
T2 = tension load at bolt 2
edge = bolt No.2 edge distance
Take moments at bolt 2 free edge contact point
It is not possible to figure out the full picture ( at least for me) .
Some questions ;
- What is the red line at the interfaces ? Rubber gasket? ( the gasket will kill the joint stiffness)
- What about the load F is this a dynamic load?
- What is the shape of T bracket and how many bolts will be used?
Short answer ;
If the red lines are not gasket, if the bolts 1 and 2 both preloaded , the joint will not separate as long as the bolts do not experience tension more then preload value . ( The preload value shall be more than 4F/3.).
The bolt 1 will be in tension with preload value and will experience more tension if the joint separates,
The bolt 2 will be in tension with preload value and will not experience compression even if the joint separates,
The shear force will be resisted by the friction developing at the interface,
Bolt 2 may subject to prying forces depending on the force level .
You mentioned that Bolt 2 at the bottom may be subjected to prying forces. But considering that Bolt 2 is located in the compression region of the T-joint due to the applied moment, how can prying occur on a bolt that's in compression?
-Bolt 2 in tension but located in compression zone.
- prying forces may develop if the base plate is not rigid enough / if the Bolt 1 yields.
The OP should clarify with providing more info.
Agree more information is meeded. However, if we’re considering the scenario where Bolt 1 yields significantly, that's already a joint failure progression, not normal service behavior. In that situation, the joint undergoes large deformations, and it's no longer appropriate to discuss standard prying actions — rather, it becomes a plastic hinge or failure mode assessment.
Okay, this is pretty similar to something I was involved in when I worked for RISA. Some references:
Steel Structures: Design & Behavior, Salmon & Johnson (3rd edition):
Chapter 4.15: Shear and Tension from Eccentric Loading
Bolt Prying in shear connections: AISC 15th Edition page 9-13. Look at the following webpage / help file specifically at the sub-section titled "eccentricities"
Some food for thought.
At the end of the day, you're adding the applied load to a preload condition. If you've calculated a suitable preload, the final condition should be that no gapping occurs (preload isn't overcome), and hence a reduced preload still exists and the joint contact surfaces are still in full contact (compression over all contacting surfaces). If gapping is to occur (even just at the onset of gapping, i.e. partial gapping due to tension and moment), it will obviously start at bolt 1. Note that gapping could just be a sign of insufficient preload, and that the tensile stresses in the bolts could still be at acceptable levels. In addition, the point of rotation (compression centroid) will be defined by joint stiffness. Best air on the side of conservatism.
