Air India 787 crashes on take off 6
LittleInch
Petroleum
GB
A full 787-8 has crashed shortly after take off in ahmedabad.
Basically barely got off the ground then look like its trying to land in this video.
Specualtion that they pulled flaps up instead of gear up and basically didn't have enough lift so it looks like a gentle stall right into a built up area.
Looks to be flaps up, slats/ nose flaps down and gear down which is very odd.
I have never seen a perm mag generator for powering the fadec depicted in any aircraft electrical block diagrams.
On our diesel engines our alternators (permanent magnet generators or whatever) were found to not be very reliable so many of our vessels run battery chargers off the AC electrical system. That was fine in the 1990's when the battery chargers were the mag-amp or transformer based chargers. However, the solid state chargers have become popular and they are not reliable. I say charger but these are really power supplies that use batteries as filters. In my fleet I replace failed solid state chargers in critical applications with mag amp units from a specific vendor.
Another question, is breaker trip sequencing a part of commercial aircraft certification? It's starting to show up in a narrow portion of marine side.
Yes but it's airframe certification, not engine.
This is the issue with the MAX they grandfathered it when it was none compliant. But the local Boeing certifiers put it through.
The other idea skulking around is some fault or override on the TCMA system designed to cut engine power when on the ground and engines at a different power level to where the throttle lever were.
Now it take a whole lot of holes to line up in the Swiss cheese, but as we've seen before, this is possible once in 15 years.
The shutdown being triggered somehow by Gear up is part of this hypothesis.
The silence from the investigation is unnerving.
That sounds like the issue for the shut down on landing of the a220 after pilot over riding the automatics and causing confusion.
It's maybe the reason why airbus opted for an in the gate and make it very special the pilots ever touch the power levers.
Airbus had issues at the beginning with the logic. There was some suspect reports on various events in hindsight to stop all fleets being grounded. They got away with it.
They appear to have been able to download the FDR and CVR from the crashed units in Delhi on Wed 25th June.
Hopefully they start giving some decent answers soon.
As the brain behind the engines, the FADEC monitors, protects and controls the aircraft propulsion system in real time. The FADEC 3 is on board many commercial aircraft such as the Airbus A318, A319, A320, A321 and A380, Boeing 737NG, 747-800, 767, 777 and 787 Dreamliner, as well as on military platforms such as the Airbus A400M.
"Modes" in FADEC reminds me of "Mission Profiles" in Phased-Array Radars. If you did not boot system in correct 'Mission Profile' the radar could not deal with incoming threat. Basically 'Mission Profile' means you need to know what threat you are trying to address, before you boot the radar, to launch the correct software. This sounds like FADEC modes, and if in incorrect mode or programmed-in incorrect information, then you end up with FADEC responding incorrectly in a very critical moment.
FADEC aka 'micro-manager'
"It was the FADEC".
That's not saying much of anything, you ask me ;)
Just a basic question from a non-pilot, non-aero engr:
Say some computer decided to roll back power (and does this actually move the levers? I think it does..). Pilot notices levers pulling back and says heck no, I need power NOW. And shoves levers to max thrust.
Who is in control at that point? Will engines respond to the pilot input, or will they respond to what ever the software wants?
May be key here...
Why is fuel cut so important that it needs to be the front and center most switch?
I'm not familiar with the 787, but with Airbus, those switches are used for the normal startup of the engines and also for the normal shutdown. Think of them as an "engine on-off switch." Internally, those switches send commands to the computer to perform a sequence of events, so it's not just a fuel cutoff. (on Airbus, there is also a mode knob between/below the switches which modifies their functionality related to engine starting).
May be key here...
I am non-pilot, non-aero engr, but from a system engineering perspective, all my reading says FADEC is in control and input from pilot on throttle is just a request by pilot, and FADEC will ignore input, if it does not agree. FADEC is not in control of BTB buss transfers in my reading, rather BCPU is in control of that function. If BCPU detected increased load on one engine VFSG, it would be in control of load transfers. It would appear BCPU had to be involved in electrical power loss to both engines and all 4 VSFGs, and if so, then it would seem that would force a rebooting of FADEC? Have no idea if FADEC moves throttle handle in over ride situation?
May be key here...
On Airbus, the thrust levers do not move by order of the computer (not sure on 787 though). On the airbus, the thrust lever setting is more of a "thrust limit" most of the time, when AutoThrust is enabled. (but moving to the full throttle position, called TOGA, will force full throttle, overriding the autothrust computer decisions; autothrust remains "armed" in this position and will take back over once the throttles are moved back to the normal [climb detent] range). With autothrust, the computer can vary the thrust as needed but the levers do not move. There are indications on the screen in front of the pilot (upper left corner above the artificial horizon) that tells the pilot what the computer is doing with the thrust. The computer does have the ability to "lock" the thrust into full throttle (called TOGA LOCK) if certain conditions are exceeded--the pilot must temporarily disengage autothrust [controlled by a button on the throttles or a button on the autopilot panel] to reset that condition).
This video explains it pretty well for the A320:
From link below:
"Disadvantages of FADEC system
1. Full authority digital engine controls have no form of manual override available, placing full authority over the operating parameters of the engine in the hands of the computer.
2. If a total FADEC failure occurs, the engine fails. (both the channels fail)
3. Upon total FADEC failure, pilots have no manual controls for engine restart, throttle, or other functions.
4. Single point of failure risk can be mitigated with redundant FADECs (assuming that the failure is a random hardware failure and not the result of a design or manufacturing error, which may cause identical failures in all identical redundant components).
5. High system complexity compared to hydro mechanical, analogue or manual control systems.
6. High system development and validation effort due to the complexity.
7. Whereas in crisis (for example, imminent terrain contact), a non-Fadec engine can produce significantly more than its rated thrust, a FADEC engine will always operate within its limits."
I understand that a complete FADEC failure would take out the engine. That seems unlikely as there are two units per engine, and I think two channels per unit, with gen power dedicated to FADEC and associated engine controls from engine gearbox.
My question is mostly that if other software systems in the aircraft, or in FADEC itself, decide to do a roll-back of thrust, can the pilot over ride that with shoving the thrust levers forward?
Seems like the Airbus system allows for such.
This is more of an anecdote that you may find amusing more than useful.
The fishing boats in Central America typically have 32 Volt starting systems and 12 Volt radios and navigation.
They Use 24 volt bulbs in the engine room.
The 32 Volts is connected to the engine room lights which are not grounded but connected to the 12 Volt electronics battery.
Advantages:
There is always light in the engine room.
The electronics batteries are always charged.
There may be some long term issues but I never saw long term planning as part of the Latin culture.
My truck is similar. It has two 12 volt alternators in series to power both 12 and 24 volt loads. The define alternator is isolated ground and it's negative terminal connects to the first battery position.
Back to FADEC, I guess the ECM on a diesel engine is the same thing. I had an interesting failure once where an engine with dual ECMs shut down suddenly without notification, all of the operating panels were still powered and showed no fault. The cause? The secondary ECM lost its personality profile. The secondary ECM saw the mismatch with the primary and took command except that it had no software to run the engine.
This falls back to one of my favorite saying is that doubling redundancy doubles the chance of a failure. An airplane with 4 engines is twice as likely to have an engine failure as an airplane with 2 engines.
An engine failure in a 4 holer leaves you with 2/3 of your performance. On a twin it leaves you with less than half.
I don't think it does kill the engine if the fade fails. You have to manually close the fuel value to be able to land though.
2 normal channels swap every start, and an emergency per engine for me. And there is cross talk so if one side gets completely blown the other can manage both engines I believe.
But we don't get taught much about them. Compared to the old analogue turboprop engines and propellers.
1. Bad News is 2020 FAA AWD I posted link to concerning the 51 day stale data 'personality change' for the Common Core System on 787s, summary below. Everything is controlled through the CSS and CDN.
"Root Cause Analysis"
"The FAA’s directive is scarce in technical details. It only contains a high-level description of the issue; however, it provides the reader with some key facts that can help with root cause analysis:
The FAA has received a report indicating that the stale-data monitoring function of CCS may be lost when continuously powered on for 51 days. This could lead to undetected or unannunciated loss of CDN message age validation, combined with a CDN switch failure. The CDN handles all the flight-critical data (including airspeed, altitude, attitude, and engine operation), and several potentially catastrophic failure scenarios can result from this situation. Potential consequences include:
  • Display of misleading primary attitude data for both pilots.
  • Display of misleading altitude on both pilots’ primary flight displays (PFDs).
  • Display of misleading airspeed data on both pilots’ PFDs, without annunciation
  • of failure, coupled with the loss of stall warning, or over-speed warning.
  • Display of misleading engine operating indications on both engines.
The potential loss of the stale-data monitoring function of the CCS when continuously powered on for 51 days, if not addressed, could result in erroneous flight-critical data being routed and displayed as valid data, which could reduce the ability of the flight crew to maintain the safe flight and landing of the airplane."
2. Link to reverse engineering analysis of this issue. If India is lax on maintenance procedures, what are the odds some updates missing? I have also seen concerns that the High Integrity Network is only virtually isolated from the rest of the low security network services. I will not try to summarize the excellent analysis linked. Author is looking for a 787 donation so he can validate his analysis.......
3. Good News is Boeing is hiring Common Core System Senior Software Engineers to oversee their outsourced Systems Engineering Suppliers.
Was watching various youtube videos regarding the crash last night, and found one that (if accurate) might be the smoking gun. Supposedly, the 787s have had a continuing problem with leaky water connections. To make matters worse, the leak is reportedly over the electronics bay.
I've felt from the beginning that the accident had to have some connection to the electrical problems on the earlier flight. Seems like if there was water leaking, initially it might have just affected some minor systems, but if things got wet enough, perhaps the whole system shorted out?
I wish I had a link to the video, but I was watching on another device.
Well your water leaks comment is timely, as FAA has issue an AD dated 16 June 25, with water leak AD's and inspections going back approximately 4 years. Electrical problem as root cause seems likely in the Common Core Equipment Rooms, and we now know a 787 engine will not keep running with loss of electrical power, as pre-FADEC engines were capable of doing. When air craft rotated, trapped water could have poured onto central electrical controls and power distribution cabinets? AD's are against air line companies and not Boeing. However, Boeing is required to furnish redesigned fixtures/parts.
